It is currently Tue Aug 11, 2026 4:23 pm
PostPosted: Tue Mar 05, 2019 6:41 am
I own a P.A. 12 -2013 Needed new set of drums -ordered the part #81173001 Mirage Drive Drum V2-the new set arrived the problem with the new set is that the bolt will not fit in the bolt hole #81155001-also the is no thread or metal ring inside the bolt hole in the new drum . Is this a defect ?
PostPosted: Tue Mar 05, 2019 9:17 am
On the V2 drum the pedal bolt threads into the plastic. Should not bee an issue.
