It is currently Sun Aug 02, 2026 11:00 pm
PostPosted: Fri May 10, 2019 9:09 am
Quick question. Is there enough room for the H-Rail Tackle Bin to mount on the inside of the rail next to the seat? I have seen them mounted on the outside (hanging over the water), but would like for it inside. Looking at it for a 2019 Pro Angler 14.
Thanks!
PostPosted: Sun May 12, 2019 5:33 am
I'm not sure about the 2019 but on my 2016 there is enough room to place it in the inside of the h-rail. But in doing so it will make it hard if not impossible to use the rod holders on whatever side your tackle bin is on. It may make it harder to use the rudder steering depending on where it is placed and it will make it hard to reach the map pocket.
I don't think there's been much change in the layout of the 2019 from the 2016 is regards to this issue.
PostPosted: Sun May 12, 2019 7:07 am
I bought two of the bins and will run them on the outside and leash everything that goes in the bins.
PostPosted: Sun May 12, 2019 8:25 am
Thanks!
Sorry I was incorrect. On my 2016 at least it will not fit between the rail and the seat.
