It is currently Tue Aug 11, 2026 7:08 am
PostPosted: Thu Apr 16, 2020 6:20 am
I just recently purchased a pa 12 with the 360 drive. I was out the other day and I moved the drive slightly to the left. When I went to move the drive back to the forward position there was a really bad noise coming from the handle. I have tried to adjust the steering tube but no matter what I do the clutch is stuck. Does anybody know what could be causing this?
PostPosted: Thu Apr 16, 2020 9:18 am
I have reached out to Phil Dow to get you some ideas - or please get the kayak over to a dealer so they can investigate - when I get a reply from Phil I'll update the forum post. Thanks.
Jacques Bernier
http://www.hobie.com/
PostPosted: Thu Apr 16, 2020 9:21 am
I called the dealer that I bought the pro angler from earlier today and they said they have to reach out to Hobie as well and look for some answers
PostPosted: Thu Apr 16, 2020 10:07 am
Sent you an e mail directly - Phil can talk to you directly - just send him your # - check your G Mail. Thanks.
Jacques Bernier
PostPosted: Sat May 04, 2024 3:30 pm
What was the resolution to this? I think I'm running into the same issue. I recently had to change my belt out because I thought it had snapped. During the disassembly, I fount the the belt was still in tact, albeit stretched at 2 of the teeth. Got the new belt in and reassembled, made all the necessary adjustments. Now the 360 handle is MUCH stiffer to turn, binds when turning left, and makes an awful squealing noise every few turns that comes from the clutch assembly. I wish there were instruction on how to inspect the actual clutch assembly.
PostPosted: Fri Dec 06, 2024 11:36 pm
Yes, What was the fix for this.... i bought a used hobie and got SEVERLY ripped off and never been able to use it but 1 time... guy supposedly took it to a hobie dealer to get it fixed.... now i got it back a month and half later.... and its worse than before. please help.
