It is currently Tue Aug 11, 2026 4:36 pm
 Post subject: PA17T Cart
PostPosted: Thu May 14, 2020 12:02 pm
I see there are 2 options, but are the tires interchangeable? The tough tire cart is 450, beach wheels are 134. Beach wheel cart is 597. Can I save $13 and have both?
 Post subject: Re: PA17T Cart
PostPosted: Thu May 14, 2020 2:56 pm
The cart will accept either tire with a simple adjustment to the axle length.
PostPosted: Fri May 15, 2020 6:40 am
Thanks Matt.
Just to clarify, because you can't really tell from the pictures, I could switch back and forth, the adjustment is not permanent?
PostPosted: Fri May 15, 2020 8:48 am
There are two hole positions for the axle. Same frame for both wheel types. Easy to adjust.
https://s3-us-west-1.amazonaws.com/media.hobie.com/item_attachments/80046201_80046202z130.pdf
