It is currently Tue Aug 11, 2026 2:09 pm
PostPosted: Mon Aug 02, 2021 4:37 pm
2021 Hobie PA 14 360 steering line diagram ? The steering line diagram on the Hobie site is not for the 2021 PA 14 360. The front left side steering line pulley is laying in the bottom of my kayak, not attached to anything. The left side front pulley does not attach in the same location as the right side front pulley. Where does this pulley attach ?
PostPosted: Mon Aug 02, 2021 5:14 pm
I will ask our tech to look in the morning. Not attached to the BOA?
PostPosted: Tue Aug 03, 2021 10:28 am
Hobie Tech / Moderator
The two cheek blocks on the top right are tied with A BLACK NYLON LINE to a plastic mold that hangs from the roof of the hull- they are different lengths as shown in the drawing. The closest cheek block to the bow on the left is tied on to a similar mold with a nylon line. The check block that the kickstand runs through is screwed to the hull. All the other remaining cheek blocks are screwed down to the hull. The cheek block should not be touching the bottom of the hull, the line should be too short.
