It is currently Tue Aug 11, 2026 7:07 am
PostPosted: Sun Sep 12, 2021 3:01 pm
The port-side rudder handle fell off while using my 2017 PA 14. It looks like there is a metal pin inside the handle broke in half. Any advice on how to fix, and part numbers much appreciated.
How does one attach images to the post?
PostPosted: Tue Sep 14, 2021 11:40 am
Using images: https://www.hobie.com/forums/viewtopic.php?f=18&t=8574
Steering handle?
88991301 STEERING HANDLE
86505401 SECONDARY STEERING HANDLE
88991235 ROLL PIN
8030125 SCREW
88991151 STICKER
https://media.hobie.com/digital_assets/Hobie_Kayak-Eclipse_August_2020.pdf#page=75
PostPosted: Tue Sep 14, 2021 3:03 pm
Yes, the steering handle. I'm attempting to post images.
Is there a resource (video, etc.) on how to replace this handle myself?
PostPosted: Tue Sep 14, 2021 4:13 pm
That is a broken screw? New crank would likely also be required.
I don't have anything specific to that situation. I'll ask my tech staff to have a look.
PostPosted: Wed Sep 15, 2021 3:03 pm
Yes, I think that is the screw that broke in half. Thank you so much. Please let me know what you find out with respect to how I can fix this.
PostPosted: Thu Sep 16, 2021 8:42 am
You need the crank and the screw it looks like. The crank will pull down into the hull. Take some photos and then pull the control line off and attach directly to the new crank... push back up through the hull and set the handle back on.
PostPosted: Fri Sep 17, 2021 8:51 am
I see several crank and screw parts listed in the document you provided. Can you list the specific crank and screw numbers and any other parts I might need please? Thank you so much.
PostPosted: Fri Sep 17, 2021 4:09 pm
Updated version is 1/4-20
84650521 STEERING CRANK PA12/14 2020 1/4-20 SCREW
88991320 STEERING HNDL TI '20- 1/4-20 SCREW
88991235 ROLL PIN
8030217 SCREW 1/4-20
88991151 STICKER
PostPosted: Tue Jul 08, 2025 5:12 pm
Hello, i have the same issue and I cant seem to find replacement parts anywhere online. May I get some leads please?
