It is currently Tue Aug 11, 2026 12:05 pm
 Post subject: 360 drive lubrication?
PostPosted: Fri Dec 10, 2021 3:31 pm
The owner's manual which came with my Pro Angler 360 kayak doesn't include any instructions about lubricating the 360 drive, and the 360 drive maintenance videos posted on Hobie's website at https://www.hobie.com/support/mirage-pr ... echnology/ don't include any videos on lubrication of the 360 drive. Does the 360 drive require periodic lubrication, and if it does, what should it be lubricated with, and where should it be lubricated?
PostPosted: Thu Dec 16, 2021 3:47 pm
Mostly all that is needed is flushing the drive with clean fresh water. Some grease is needed on the idler cables to keep them from making noise as they run across the drums, and periodically some silicone spray on the pedal axles.
Jacques Bernier
http://www.hobie.com/
