It is currently Tue Aug 11, 2026 1:08 pm
PostPosted: Thu Jan 13, 2022 12:33 pm
Hello Hobie boards!
Long time viewer first time poster, and I need some assistance.
I purchased a secondhand PA17 (upgrading from an Oasis), and while going through the boat, the rudder tensioning BOA knob snapped.
I've attached a couple pictures- it may be hard to tell, but the knob itself is cracked in the geared/center portion and can no longer be clicked back in. As such, I can't get any rudder tension!
I've been looking all over on where to get the replacement knob. From what I can find looking at pictures, it looks like it is BOA's "H3" system but I can't even find replacements knowing that. Iv'e also reached out to BOA, but they've been unresponsive.
Any suggestions on what I can do? Thank you!
PostPosted: Thu Jan 13, 2022 8:29 pm
In 2014 Hobie came out with the rudder BOA for the PA-14 and I wanted to upgrade my 2013 PA-14 with the BOA, so I purchased a retrofit kit and the BOA P/N was 84507881, rudder tension replacement.
That's the complete BOA assembly.
I can't imagine that Hobie used a special BOA for the PA-17, but if you start with this part number above, I am sure Hobie can tell you if it's common across the whole PA family.
Good Luck!
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Thu Jan 13, 2022 8:31 pm
By the way, if you were unaware of the BOA release, you pull out the knob to release the tension.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Mon Jan 17, 2022 1:32 pm
Hobie Tech / Moderator
BOA STEERING LINE TENSION REPL - 84507881
You can place an order for this part at an authorized Hobie dealer.
