It is currently Tue Aug 11, 2026 8:24 am
PostPosted: Tue Sep 26, 2023 10:23 am
I have a 2022 hobie PA 12 with the 360 mirage drive. For some reason it started rubbing on one side of the drive. The part that rubs is the side facing the drive gear in the kayak. The plastic housing seems like it is where it’s supposed to be, but it’s like the whole drive needs to shift to the right. When pedaling you can see the grey plastic component under the pedal adjustment arrow move back and forth. Any ideas what I can do to adjust my pedal position so it does not rub anymore? It only needs like 1/4 an inch but I don’t know what the adjustment is for that or if there is one. I have adjusted global screws and my drive tension cables are the right resistance. I have adjusted everything I can think of and it still rubs. It has actually rubbed down the little fin type molding on the gray composite structural piece of the drive so it is almost flat on a small section.
