It is currently Tue Aug 11, 2026 7:06 am
PostPosted: Sun Jun 09, 2024 8:51 am
What is the pin called that goes into the hole on the top of the rudder bracket? That pin also goes into the bottom of the rudder drum. I have taken my used kayak out four times and have had an issue every time. First the rudder mount snapped in half. Replaced it. Then the sleeve the rudder mount was in- I lost it. Cool replace all that and boom. Now I use my steering handles- my drum turns as it should but the rudder does not move. All string appears to be good. I watched videos and there’s a pin through the top of the rudder mount - almost holding the mount from falling through(without having the drum connected) I am missing that pin and can’t find it anywhere! Any help would be super appreciated. Thank you for reading and taking the time to help.
PostPosted: Mon Jun 10, 2024 2:59 pm
Here are all the parts going into the rear rudder assembly. This is for a post model year 2013, PA-14 but the PA-12 uses the same parts.
I think you are asking about the pin that's missing. P/N 88991235
84500601 COVER PLT, RDR SYSTEM
8030151 SCREW (4)
84500801 TUBE RESTRICTOR (2)
84500501 STEERING DRUM (PIN TYPE OLDER)
8060141 COTTER KEY (REPL ROLL PIN)
84500502 STEERING DRUM (SCREW TYPE)
8030126 SCREW
88991235 PIN
84500402 RDR MOUNT, UNDER HULL (SCREW TYPE)
84500201 RUDDER HOUSING, UNDER HULL
84502301 SISTER SCREW, PRO RDR ASSY
8031490 SCREW SCREW 8-32 X 1/2 FHMS-P
84504001 TORSION SPRING, RUDDER
84500101 RUDDER BLADE, PRO A
84612001 RUDDER BLADE, LARGE PRO A
Dr.SteelheadCatcher
Warrenton, OR
