It is currently Sat Aug 01, 2026 6:47 pm
 Post subject: What BLOCK HANGER to use
PostPosted: Tue Jul 10, 2007 1:41 am
I just upgraded my seaway blobks to a 6:1 Harken stetup with a
2605 BLK-57MM CARBO TRPL W/BKT
Description Triple/swivel/becket
Where would you fix it....I´m using the middle block hanger...and the main sheet does not seem very vertical...more like inclined aft...
 Post subject: Block hanger
PostPosted: Tue Jul 10, 2007 8:46 am
The sheets should angle aft to give compression force forward against the mast to hold the mast in rotation.
PostPosted: Tue Jul 10, 2007 11:32 pm
The middle of three hangers on my 18 is bent likely because of too much pressure, so I've moved to the hanger closest to the rear cross bar.[/i]
PostPosted: Thu Jul 12, 2007 8:53 am
I use the middle hanger on my 18 boom and took the others off. Kept hitting them with my head or hanging them on the harness/jacket.
PostPosted: Thu Jul 12, 2007 2:52 pm
the aft hanger worked best for me. it allowed for some rotation control :)
Tom & Nancy Page H20 803
