It is currently Sat Aug 01, 2026 9:35 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Wed Aug 20, 2008 11:00 am
Inflating to the maximum rated pressure will also wear your tires out down the middle, requiring them to be replaced more frequently. I have a fairly heavy-duty trailer carrying a Hobie 16 w/ sailbox, sails, and a few other odds and ends on 4.8 x 8 tires. I find that about 45 psi works much better than the 60 or 65 psi max.
Jerome Vaughan
Hobie 16
Clinton, Mi'sippi
PostPosted: Thu Aug 28, 2008 11:57 am
ok, so my latest run i was almost happy with it. i ran 45 pounds of pressure. that seemed to calm it down alot, and then i also tied from the mast spreader to the hobies wings. this kept the mast still and quieted it down alot!
The only other thing i want to do is add some protection to the front of the hulls and find a better way to secure the rudders since i think a good bump can release them and send them downward.
PostPosted: Thu Aug 28, 2008 12:45 pm
Many folks will tell you to take the rudders off the boat when trailering. Not a bad idea, but personally I don't think it's absolutely necessary, especially for a cruising sailor.
For securing my rudders, I secure the tiller extension to the rear crossbar using the traveler cleat, so the rudders stay straight. Then I've got two lengths of nylon webbing with an adjustable clip-in buckle on the end (like you would find on many life jackets). I use one for each rudder. Throw one wrap around the tiller arm, pass it under the hull, snap the ends together and sinch it tight. The rudder isn't going anywhere.
PostPosted: Thu Aug 28, 2008 2:18 pm
I wouldn't do this. The spreaders are easy to bend and expensive to replace...if they're even still available.
Just tie off the mast if you feel the need.
TC
PostPosted: Thu Aug 28, 2008 4:11 pm
Blast! you always shoot down my good ideas. lol
PostPosted: Thu Aug 28, 2008 4:17 pm
Unfortunately a lot of it comes from been there done that... lessons learned.
TC
