It is currently Sun Aug 02, 2026 4:11 am
 Post subject: Re: Let's talk trailers
PostPosted: Tue Sep 08, 2009 3:58 pm
My steel monster tows like like a dream. Straight as an arrow and smooth. I managed 26 mpg the last time that I towed the boat to a regatta (this time last year :( )
It just weighs a TON and I've already had to replace the transmission in the car once (unsure if it was towing related or lead foot related). I'm 100 lbs under the maximum payload, but find the transmission doing a lot of downshifting on small hills.
I suppose I'll keep my eye out for a used trailex or a beater pickup. Whatever comes up first that will eliminate the wear and tear on my econo car.
I suppose the upholstery is taking more abuse than the transmission. Drove some people from the office to lunch today and they all complained that the car smelled. I guess my wet main sheet and pfd's in the trunk didn't help.
PostPosted: Tue Sep 08, 2009 10:14 pm
Here is the best tow vehicle. This can carry everything dry and friends and family with two big dogs.
http://cgi.ebay.com/ebaymotors/2002-FORD-E350-15-PASSENGER-QUIGLEY-4X4-VAN_W0QQitemZ260472945055QQcmdZViewItemQQptZUS_Cars_Trucks?hash=item3ca565b99f&_trksid=p4506.c0.m245
Best purchase I made next to the 21SE. :mrgreen:
PostPosted: Wed Sep 09, 2009 8:25 pm
I have an old trailex; the style with the center beam/tongue that only runs to the front cross-beam and is supported by two additional beams that meet up with the center beam at 45 degrees. The only complaint that I have is that the trailer tends to wag behind me a little as the unsupported portion of the tongue flexes back and forth. Also, the mast stand sits in the center of this unsupported section (between the coupler and the point where the diagonal support beams mean the tongue) and as it sways back and forth in the turbulent air behind my Jeep it twists the tongue repeatedly. I worry about fatigue in the aluminum so I keep an eye out for cracks.
I have a feeling that the trailex on the fist page of this thread would suffer from twisting and waging even more as it has a longer stretch of unsupported tongue. An ideal design in my opinion would be to add diagonal supports from the front corners of the frame all the way to the coupler, and to add a cross brace where the mast stand is attached. Another option would be to stick with the design in that picture but replace the center beam with one made of a more rigid material like galvanized steel while leaving the rest of the trailer aluminum for weight savings. It would be one heavier beam vs. adding additional aluminum beams. At least with the diagonal beams you would have a decent area to mount a box at the front of the trailer for storage.
As far as hills go... I don't have problem. My Jeep produces so much drag already its pretty hard to notice any more. Crosswinds are another issue though....
(and those power lines are plenty far away... no worries)
PostPosted: Thu Sep 10, 2009 6:53 pm
spesce wrote:
here is the best tow vehicle.
I envy you! that is cool! Mine is 2wd but it will haul it all!!!
PostPosted: Sun Sep 13, 2009 9:07 am
That was an example as I bought mine on Ebay 4 years ago. Best weekend vehicle espescially for snow and sand. Here is my van with the 21SE on the back. I also get 15 mpg!!!
PostPosted: Sun Sep 13, 2009 9:24 am
I like my tow vehicle the best of any I've ever owned. A diesel dually 6x6 running on biodiesel. Gets 18.8 miles per gallon of french fry oil and the extended 21 doesn't even look wide behind it.
PostPosted: Tue Sep 15, 2009 11:10 am
Has anyone had any experience towing a boat behind a 5th wheel? Towing doubles is illeagle in texas but I see people pulling boats behind their 5th wheel every once in a while. I have a cab-over camper on an F-250 diesel and it is ok for comfort (AC/heat, refridge, bathroom, etc), but I have space envy for the fifth wheel trailers. I've always wondered if the 5th wheel trailer is exempt from the doubles law or if the people were just hoping not to get pulled over.
PostPosted: Tue Sep 15, 2009 11:24 am
Here in Colorado, we have three families that use Ford F-250's to pull a 5th wheel with a Hobie hitched to the back of the 5th wheel.
One family pulls a H-17
One family is pulling a H-18
One family was pulling a H-20 and now is pulling a Tiger.
Going down the interstate it looks a little dicy to me, but they all say it's no problem.
