It is currently Tue Aug 11, 2026 11:18 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Tue May 05, 2015 6:27 pm
rattle 'n hum wrote:
I sometimes wonder if my steel mast crutch is beefy enough....can't imagine PVC working for long. (And don't even want to think about the consequences of a failure!)
I only live a mile from my boat launch, so not going far. but thanks for your input, with that info I may be going the steel route
PostPosted: Fri May 08, 2015 8:08 am
Restoring gel coat is relatively straightforward, but can be a long process. Basically, you want to take the chalkiness out, which is done by removing a very small layer of gel coat. The same process is used for removing scratches, swirl marks, or sanding down and polishing a new coat of gel coat. For a new boat, wax is all it takes to remove minimal oxidation. For a slightly older boat, it might be a hand polishing, followed by wax. Older still, a mechanical polishing, followed by wax, and so-on and so-forth. For the very worst level of oxidation/deep scratches/new gel coat, the process would be:
1) Sand the hull using sand paper, from perhaps 400, grit to 600, 800, 1,000, 1,200 and 1,500 grit.
2) Use a "Rubbing/Buffing compound" and a variable low speed buffer & wool pad at 1,500 - 2,500 rpm
3) Use a "Polishing compound" and a variable low speed buffer & wool pad at 1,500 - 2,500 rpm
4) Seal and/or wax the hull
Common products:
3M Rubbing Compound/Imperial Compound & Finishing Material
3M Finesse-it II glaze (polish)
Collinite 920 (hand polish)
Starbrite Premium Marine Polish w/PTEF (sealant) - doesn't remove chalkiness, but protects from future oxidation. Apply before waxing.
Collinite 885 (wax)
Moderate Oxidation will need steps 3 & 4, Heavy needs 2-4, and Severe may need step 1. However, if you're applying new gel, are you all that concerned about the old oxidation? Also note that 5 coats sounds like a lot. I'd recommend 1 or 2. Gel coat adds a lot of weight!
Anyways, that should be enough to get you started. Googling it will get you much more information!
Mike
'78 H18 (unnamed) sail #14921
'08 H16 sail #114312
'97 H21SC sail #238
Last edited by SabresfortheCup on Mon Jun 22, 2015 7:24 am, edited 1 time in total.
PostPosted: Mon May 11, 2015 8:09 am
Here she is
PostPosted: Tue May 19, 2015 9:01 pm
looks like I'm not the only one with black hulls that I know of anymore.
Catamaran Racing Association of Michigan - Marketing Officer
USF18 - Social Media Manager
2010 NACRA Infusion
2004 F18 Hobie Tiger - SOLD
Hobie 16 - BREAKPOINT - SOLD
PostPosted: Tue May 26, 2015 11:46 am
This is awesome. Thanks for sharing.
PostPosted: Wed May 27, 2015 7:20 am
You could get a steel one welded up for a small amount........ or trade a case of beer!!!!!!. Use a Bow Stop for the cradle.
