It is currently Sun Aug 02, 2026 1:12 am
 Post subject: Lower rudder casting
PostPosted: Wed Oct 22, 2008 7:44 am
I broke the non adjustable rudder casting on my '84 H 16 recently trying to get the cam unjammed. The thin metal crossover piece broke off. I need to replace it. Will an adjustable casting work or do I need to find an old one?
I am having problems getting these to work properly even though I have replaced the cams, plugs, and springs. The plugs try to squirt out from under the cams. The cams then over rotate and won't hold down the rudders. Anyone have any thoughts on this problem?
Thanks!
Kent
PostPosted: Wed Oct 22, 2008 10:21 am
Seeing as you have the non-adj type, the hole placement in your rudders are all you have to adjust the geometry. I suspect that the holes in your rudders are worn. You may have to fill and redrill your rudders. Your castings may be worn as well. I've seen where the hole that the plunger goes through widen and cause the plunger to rotate. This will also happen when the cam sister screw holes are elongated. The cam will move up and allow the plunger to slip through the space between the cam and the casting. Did that sentience even make sense? Bottom line is that something is worn out of tolerance. Try to grease up the area where the cam runs on the plunger and see what happens. That solves about 50% of all old rudder maladies. It's not the right way to do it, but when the real fix is time consuming or expensive, it's a good temporary solution to get back on the water. Try loosening the plunger adj as well. Send us some pics and we can better assist.
The adj casting will work in combination with your older upper.
This might help:
http://www.youtube.com/watch?v=zUUA7l6fzIk
Sail Revolution
Join us on our new FB Page!
PostPosted: Wed Oct 22, 2008 1:02 pm
I see a bunch of the old style castings are on e-bay.Take a look there for a replacement.
PostPosted: Wed Oct 22, 2008 8:24 pm
Thanks for your ideas. I'm sure the problem is a combination of all of the above. I did see the older castings on ebay but was concerned that I'd just get one that was as worn as the one I have. Since new castings are about $150 I'll probably try a used one.
Thanks also for the video, that helped give me a better picture of how it really works.
Kent
