It is currently Sun Aug 02, 2026 4:09 am
 Post subject: converted beach wheels
PostPosted: Sun May 17, 2009 10:15 pm
I have this jetski beach cart and was thinking of converting to use with a 21 SE. Basically I was going to place a craddle centered on each axle so there would be two wheels for each hull. The wheels are approximately 14-16 inches in diameter and therefore, I was going make the cradles at least 18 inches high. I will connect the axles to each other with square tubing and put the wagon handle to be able to pull if needed. Any thoughts or input on what I should look out for?
