It is currently Sun Aug 02, 2026 3:02 am
 Post subject: rudders
PostPosted: Sat Jul 11, 2009 8:07 am
Can I use rudders from a Hobie 17 on a 16? I think the answer is yes, but I don't know.
James
86' Redline Hobie 16
Sail # 76909
 Post subject: Re: rudders
PostPosted: Sat Jul 11, 2009 9:24 am
The entire rudder system? The biggest issue will be the lower casting. There is a difference in the gudgeons and their spacing. I doubt there is room on the transom for the required spacing.
PostPosted: Sat Jul 11, 2009 9:38 am
No, just the rudders. I would be using the 16 assembly and castings.
James
Sail # 76909
PostPosted: Sat Jul 11, 2009 9:51 am
You can use them, but the bolt holes are in different locations.
I used to have a spare rudder that was drilled for both - my recollection is that the hole for the upper casting is roughly in the same location for both (or at least you can make it work there).
PostPosted: Sat Jul 11, 2009 1:53 pm
Ok. Thanks for the replies. I'm looking to buy a pair of EPO's that were used on a 17. I assume I can fill and drill as need be as long as the rudders are the same.
James
Sail # 76909
PostPosted: Sat Jul 11, 2009 2:54 pm
Yes... that would work. You will love the EPOs!
PostPosted: Sat Jul 11, 2009 5:20 pm
Thanks for your quick replies. I'm really digging this racing thing and I'm now looking for more of the go-fast stuff.
James
Sail # 76909
