It is currently Thu Aug 20, 2026 11:26 pm
PostPosted: Sat Aug 15, 2009 7:11 pm
I currently have a yellow nationals sail set ( with a rainbow stripe set in the center) that has a really tired jib. I see in the catalog they list only white and turquoise hobie 18 jibs, and there is no mention of anything like the special order catagory listed under the H-16. Question one: can you get a special order H-18 jib....Question two: if so, what does that get you...just a solid color jib, or can you really get a matching jib, and at what cost.
PostPosted: Sun Aug 16, 2009 5:10 am
Matt Miller is the authority here on that, but I can tell you that the multicolored "rainbow" stripe cloth is definitely no longer available.
Hobie Cat only stocks a limited number of sailcloth colors - white, blue, red, yellow and gray are common. They may have some "bolt ends" of other colors.
PostPosted: Mon Aug 17, 2009 9:50 am
Custom jib color is an option Part # 60992991 currently $630 Choose from current colors. Correct... no rainbow materials in stock. Just solids.
PostPosted: Sat Jul 31, 2021 7:46 pm
Our 1982 Hobie 18 jib (rainbow colors matching mainsail) should probably be replaced.
Is this still the situation (solid colors only)?
PostPosted: Sun Aug 01, 2021 8:14 pm
Yes - the "rainbow" panels have not been available for many, many years. The MOQs are just too large to justify stocking the material.
