It is currently Sun Aug 02, 2026 2:54 am
 Post subject: mast stepping
PostPosted: Fri Aug 21, 2009 6:56 pm
Jim here. Just got new shrouds for my 18. They measure 20'5" just as hobie wire chart states. Problem is the original 1990 ones I took off are 20'71/4". Any body know if the length changed from year to year? Can not get forestay to reach furler adjuster. Forestay measures 17'2" as per hobie wire guide. :( :( :(
ADDICTION
1989 HOBIE 18 SE/sx wings
HOBIE ALTER SIGNATURE MODEL
 Post subject: Re: mast stepping
PostPosted: Fri Aug 21, 2009 8:35 pm
you need to upgrade to a new forstay, or save money and add a second 10 hole adjuster in line. all for stay does is hold mast up until you tension the JIB
PostPosted: Sat Aug 22, 2009 4:55 am
What do you mean upgrade? My rigging is exactly as 2009 parts catalog shows. Forestay adjuster is 12 holed, forestay is 17'2", pigtail is 241/2", bridles 351/8" just as stated in hobie wire guide. Problem is old shrouds 22'5" as compared to new ones at 20'5", can not reach furler adjuster with new shrouds. I also had replaced forestay but don't have old one to compare length to. Maybe it was longer also. I am comming up about 4" short even with adjuster all the way up and shrouds in upper chain plate hole. :( :?:
ADDICTION
PostPosted: Sat Aug 22, 2009 10:01 am
Just put old shrouds back on. Mast steps without problems. Brings me back to original question. Did the 18 have different shroud lengths in 1990?
ADDICTION
PostPosted: Sat Aug 22, 2009 4:56 pm
sorry my mistake i thought you were talking about a 16. SORRY
PostPosted: Sat Aug 22, 2009 11:38 pm
G'day Hobie911
I would look again at your bridle lengths they sound short
4. WIRES
Bridle lengths shall not be shorter that 41 in, (104.14 cm) pin to pin.
Mark
