It is currently Sat Jun 20, 2026 10:08 am
PostPosted: Sat Jan 07, 2006 6:53 am
If you can leave it on the beach with the mast up? I live on the shore of a lake and would take the boat out of the water and take down the sails but I dont need to unstep the mast every time. Any advice on how long it will take to get on the water if all I have to do is put the sails up and shove off?
Also, I will be sometimes alone and sometimes with a friend.
PostPosted: Sat Jan 07, 2006 7:24 am
15-20 minutes. Thats with a beer in hand and being careful not to spill.
Pat Bisesi
Fleet 204 Syracuse, NY
PostPosted: Sun Jan 08, 2006 2:49 pm
If you can leave the mast up? 15 minutes max!
PostPosted: Mon Jan 09, 2006 6:26 am
A sailing buddy and I could fully rig two H16's from the trailers in 20 minutes. A single H16 where you onlyhave to raise the sails? Max 10 minutes. Maybe 15 if you count dragging it into the water.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Mon Jan 09, 2006 8:37 am
Yes, it is a beautiful thing. That's why I've nicknamed our 16 the "throw and go" boat :D
Gosh, I'd guess you're looking at 10 to 15 minutes tops, with a Wave 8)
Consider yourself very fortunate to have mast up storage and live there to boot! (read major envy!) If I was in your shoes, I'd have our 18 or 20 sitting out there with a sock on the roller furling jib. You wouldn't be talking about any more time, but I guess you'd always want a friend along.
Fleet 297
PostPosted: Tue Jan 10, 2006 12:40 am
If you can leave the mast up, ans are in a relatively secure location, where you can just undo the jib sheet and main sheet shackles, and just remove the sails, and the Boom.
10-15 minutes like everyone is saying Max.
PostPosted: Wed Jan 25, 2006 10:41 pm
10- 15 minutes is way to long if the mast is already up. ive seen it done repeatedly in 8 minutes, less if your sail goes up easily.
when your batons start to snap and the wind is at your back, you see a white cap, and your on a hobie cat, pull in your lines and you see it start to rise
does
your jib hang low
