It is currently Sun Aug 02, 2026 4:09 am
 Post subject: ez lock for getaway?
PostPosted: Mon Nov 23, 2009 7:25 pm
My getaway has the old 2003 steering system on it,is it worth changing to the new ez loc system and can it be factory fitted with glass rudders instead of plastic?
Just like a bit more performance for racing.
Tasmanias only getaway sailor.
How much would the whole system be with glass rudders?
spose i could get a price from steve in sydney?
 Post subject: Re: ez lock for getaway?
PostPosted: Mon Nov 23, 2009 7:30 pm
To the best of my knowledge, Hobie Cat does not make fiberglass rudders that fit the EZ-Loc system.
You're better off keeping the existing rudder system and changing out the blades to EPOs.
PostPosted: Mon Nov 23, 2009 8:57 pm
Humm,, sounds like an opportunity to me!! :idea:
PostPosted: Tue Nov 24, 2009 11:21 am
Mr Bounds is correct. The Ez Loc rudder system only works with the plastic blades which have special indents molded for the rudder locking system.
PostPosted: Tue Nov 24, 2009 4:54 pm
Thanks guys,new blades sound the go.Just gotta work out the cranky cam system,my port rudder pops up when under a bit of pressure or a decent wave hits it,tried everything to fix it according to the manual??what gives???help! :?:
Tasmania's only getaway sailor!
PostPosted: Tue Nov 24, 2009 5:51 pm
1) Adjust the lockdown plate (top casting). It might be too far forward - not allowing the cam to fully seat when locked down. You should hear a resounding "snap" when the rudder locks down.
2) Replace the cam. The corners of the indent on the bottom might be worn, allowing it to rotate prematurely.
PostPosted: Wed Nov 25, 2009 11:18 am
There is a detailed rudder adjustment article in the sailing FAQ:
http://www.hobiecat.com/community/viewtopic.php?f=18&t=467
PostPosted: Wed Nov 25, 2009 9:26 pm
yep,lockdown plate is probably too far forwards,got new cam kit not long ago so it should all be good,time to do some fiddling,thank you for your help gentleman very appreciated.
PostPosted: Thu Nov 26, 2009 10:41 am
Question, could you take a couple of epo rudders from a 16 and mill the dimples in them for the new style getaway?
