It is currently Sat Aug 01, 2026 12:26 pm
PostPosted: Thu Dec 29, 2005 4:57 pm
Although it's not class legal, I'd like to put a mast rotation control arm on my 16. Does anyone know of a diagram illustrating it's configuration and where I might find it? Thanks
PostPosted: Thu Dec 29, 2005 5:07 pm
I won't post the photo in-line because it's too large, but here's a link to what was proposed to (and ultimately rejected by) the IHCA Rules Committee.
http://www.sa.bvit.com.au/site/hobie/image/fullsize/1425.jpg
PostPosted: Fri Dec 30, 2005 6:44 am
Hey, I like the swivel cleat for the downhaul/cunningham, but that's not legal (the swivel) or is it?
Fleet 297
PostPosted: Fri Dec 30, 2005 6:52 am
Those are prototype photos done by Hobie Europe.
The swivel is not class legal - the lower attachment point presented some problems (How are we going to anchor this?) and that was an easy fix.
The approved attachment is an adaptation of the top plate off the main traveller. The cleat cannot swivel, although there is some limited side-to-side movement.
A interim ruling was just issued stating that the cleat has to be on the bottom. A couple of inventive sailors figured out that if they reversed the system (by mounting the cleat to the gooseneck), that they could get more swivel action out of it.
All of this stuff is on the Rules Forum on the IHCA website - http://www.hobieclass.com
PostPosted: Fri Dec 30, 2005 7:11 am
I was thinking of "threading" a small eyestrap through the eyestrap mounted atop (or bottom in the case) of a triple block/with cleat and securing that using #10-32 nuts in the mast track. But this probably would allow 30 to 45 degrees of sideways movement. I was just trying to think of the most economical way to attach a "standard" block to the mast. What do you think? If I don't try to somehow run the control line to the side rail/s (run straight aft) will this "fly"?
Fleet 297
