It is currently Sun Aug 02, 2026 12:34 am
 Post subject: H18 vs Seaweed help?
PostPosted: Sun May 29, 2011 7:24 am
Seaweed is really bad in the gulf right now so I need to be able to pop my rudders up while on the water to free the seaweed build up. Any tips on setting up my cams so I can manually release them on the water? Last time I tried the cam stop plate just bent the cam tip it did not release and I could not get my rudder back down because the cam was locked down.
Floyd
00 Tiger
http://www.HobieFleet33.com
10 Mile Surfside, Texas
Join us on our Facebook group: Surfside Sailing
 Post subject: Re: H18 vs Seaweed help?
PostPosted: Sun May 29, 2011 7:34 pm
Your cam tension screw is too tight? The big, plastic screw under the bottom rudder casting.
PostPosted: Tue May 31, 2011 9:56 am
I had a similar problem. I inspected the cam closely it had a crack which allowed the rudder to pop up without releasing the cam tip. It was hard to see the crack it was so small. The crack allowed the cam to flex enough to let the cam follower by. So when I wanted to rudder to lock back down it wouldn't cause the cam was still in the down position, just like you. I would take the main sheet tie it in a loop and then lasso the cam and give it a good yank upwards and FWD to get it to pop up. I got good at lassoing but when I saw the crack I replaced it and my lasso skills are going to waste.
If it has no crack then its what SKIPSHOT said.
Sail # 10505 or 277
Image Image
PostPosted: Tue May 31, 2011 6:10 pm
Buy some sailkote and spray it on the cam, top and bottom. The cams get sticky over time from salt and sand, some dry lube goes a long way. My screws are in tight and the rudders pop everytime. New cams is always a good idea. You can also pop them if stuck down while on the water by hooking the main sheet around the bottom of the cam, do not pull on the arm, and jerking it up with a swift, strong motion.
PostPosted: Fri Jun 03, 2011 2:00 pm
I bought a new cam and a fish weight scale so I can set how many pounds of force it should take to pop up the cam I saw post somewhere about this magic number.
Floyd
00 Tiger
PostPosted: Fri Jun 03, 2011 2:41 pm
I do this in a race if time is important, otherwise I take a screwdriver from my tramp bag and jump in the water with it and stick the screwdriver between the cam and the plunger and pry the cam loose. I think I may have screwed up my lower casting by using the mainsheet method too many times, because now the plunger squeezes out the wrong way from the casting when the rudders contact the bottom and pop up.
PostPosted: Sun Jun 05, 2011 7:31 am
I bought the tool in the catalog for $6.10 you just drill a 3/16 hole on the bottom of the cam and the tool works like charm. I set my rudder cam to 15lbs with the fishing scale and they release when I pull up on the bar now. The mainsheet trick bent my cam so I replaced it.
Floyd
00 Tiger
PostPosted: Mon Jun 13, 2011 8:22 am
I set mine at 15lbs but they are kicking up due to the seaweed I think but not sure there was a ton of seaweed on the beach this weekend and some patches in the water so I may bring the tension up to 18 and see how it holds next weekend.
Floyd
00 Tiger
PostPosted: Mon Jun 13, 2011 9:16 am
The other thing you can do is tie bungee around your rudder/rudder pin. Hobie & Murrays sell flared washers that you install on the lower rudder castings (on the outside of the casting) that act as guides for the bungee.
The advantage of using bungee is that you get increased hold-down force on the rudder without having to increase the pressure on the cam spring. This means your cams will still rotate when you lift the tiller arm. If you simply continue to increase the pressure on the cam spring, eventually the cam won't rotate anymore (the spring will be bottomed out).
