It is currently Sat Aug 01, 2026 8:53 pm
PostPosted: Sun Aug 20, 2006 12:38 am
Hi guys what setup should i do for my H18??
6:1 or 7:1??
Rachet? on both top and bottom? only bottom?
What is the objective of a rachetting block? make it easyer to hold the line when uncleated correct?
Rachmatic , rachet? what would you get? :)
Also what mainsheet would you recomend and why?
3/8" or 7/16"
Theser are some recomended options by my dealer
1) 6:1 - 3/8" mainsheet
lower: HAR 2141 - $175.85 US
or HAR 2630 - $240.20 US
upper: HAR 2604 - $114.30 US
2) 7:1 - 3/8" mainsheet
lower: HAR 2141- $175.85 + HAR 2636 - $22.80 US installed on the 2141 becket.
or HAR 2632 - $257.30 US
upper: HAR 2605 - $120.25 US
3) 6:1 - 7/16" mainsheet
lower: HAR 2686 - $310.20 US
upper: HAR 2664 - $166.90 US
4) 7:1 - 7/16" mainsheet
lower: HAR 2687 - $349.65 US
upper: HAR 2665 - $176.85 US
Thanks!
PostPosted: Mon Aug 21, 2006 5:34 am
My H18 came with a good setup. I'm not sure of the part numbers, but they are all Harken. I have a 7:1 setup and the lower block only has the ratchet. This ratio is a good balance between the amount force needed to sheet in and the amount of line.
Get the ratcheting block. On a long gusty day you will be very glad you did. You are correct in saying that is helps hold the sail without cleating. Well worth the money.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Mon Aug 21, 2006 6:17 am
I run a 8:1 system I removed from my Fox before selling it. It has the ratchet on the lower which I would recommend. Don't see a need for racheting upper blocks.
