It is currently Sat Aug 01, 2026 7:40 pm
 Post subject: Hobie 21SE mast repair
PostPosted: Sun Jan 13, 2013 2:35 am
I need to repair my mast for my Hobie 21 SE mast. The previous owner dropped the mast and put a small dent and slight bend in the mast. The mast is no longer available and a replacement would cost appx 3000 so repair is the way to go.
My idea;
about 1 meter long
sleeve the mast with a ud glass/carbon, epoxy, vacuumed sleeve
layup would be
600gm ud glass
3x 280 bd carbon
600gm ud glass
This would be formed from a mold formed inside the mast and the vacuum molded.
'then it would be epoxied and riveted inside the mast.
Doe this sound like it would work?
PostPosted: Sun Jan 13, 2013 9:08 am
A "small" dent shouldn't be that much of an issue.
Where is the dent and what are the dimensions?
How do you plan to fix the bend?
Photos would be really helpful.
