It is currently Sat Aug 01, 2026 8:54 pm
 Post subject: Cracks
PostPosted: Thu Jan 17, 2013 9:56 pm
These cracks are on the rudder mount (not sure of exact term) on A H16 that I am considering for purchase. Hull is in great shape otherwise. Cosmetic or serious? Thanks for any help. Hope that the pic shows up.
 Post subject: Re: Cracks
PostPosted: Fri Jan 18, 2013 3:52 pm
No biggie, very common. Check the hulls carefully for soft spots!
1980 H16
PostPosted: Fri Jan 18, 2013 4:10 pm
Thank you! Are soft spots in the hulls acceptable or should they be avoided completely? I believe this boat may have a baseball size spot.
PostPosted: Fri Jan 18, 2013 5:06 pm
Small areas are repairable. There is a description of a resin injection technique in the sailing FAQ.
Note... the boat has been painted.
PostPosted: Fri Jan 18, 2013 5:26 pm
Thank you Matt. Is that an issue as well? What should I look for in that respect (the hulls being painted)? Still havent seen it in person as it is 4 hrs away. Trying to establish if it is worth the trip. Thanks for the help. Brand new to this.
