It is currently Sat Aug 01, 2026 11:16 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
PostPosted: Mon Apr 29, 2013 10:14 am
It feels to me on my H16 like am 'faster' and make fewer mistakes when racing on a port tack as compared to a starboard tack. Being right handed the tiller is in my dominate hand, and I am also right eye dominate
Does anyone else notice this? Or given this any thought?
I have heard of car racers also being faster turning one direction than the other.
Any tricks on communicating with my left arm better. :lol:
www.thehobiewayoflife.com
PostPosted: Mon Apr 29, 2013 11:39 am
NASCAR drivers are fastest on left turns.
Jonathan
'85 H16 __/) 87468 Tidal Wave
PostPosted: Mon Apr 29, 2013 12:06 pm
No, they are faster after the left turn.
PostPosted: Mon Apr 29, 2013 12:27 pm
:mrgreen:
Seriously. Next time you try and put on a coat try and put the 'other' arm in first
Or. The neighbor kids love to come powersliding to a stop on their bmx bikes. The left based kid rotates clockwise into a slide the right hand kids rotate counterclockwise more often than not.
Maybe NASCAR drivers ended up going left because it simply seemed more natural for more people.
PostPosted: Mon Apr 29, 2013 4:31 pm
Steering wheel is on the left. Need th be able to see the inside lane/edge of track.
PostPosted: Mon Apr 29, 2013 7:23 pm
Ron Holm, looks like others notice this too on all different kinds of boat's http://www.bing.com/search?q=sail+faster+port+starboard
I wonder about slight differences in hull symmetry, hull weight, Rudder alignment, batten flex, mast rotation, etc. One ear better than other making it seem so :)
Jonathan
PostPosted: Mon Apr 29, 2013 9:10 pm
Nascar turns left because the driver is on the left. If they hit the wall the driver is more protected. In Australia the oval track racers turn right.
Rich Vilvens
F-18 5150
PostPosted: Mon Apr 29, 2013 9:32 pm
You have to also consider that they're turning right AS WELL AS racing upside down. Man, have they got it tough, driving on the wrong side of the road and upside down. all at the same time.
'79 H16 "Carmelita"
PostPosted: Tue Apr 30, 2013 5:38 pm
Not getting any help from the crew on this one, eh Ron! :roll:
I share the same physical setup as you and I am still learning the ropes on various cats, so this interests me too.
One would think that, on a well-tuned boat, having the dominant arm and eye forward (starboard tack) would provide a better sense of balance, vision and control (while flying at least) but this may not be the case. Maybe the "Goofy-foot" analogy is closer to the truth when sailing. (Righty's feel more natural leading with their left side). Boxing and other sports - same thing.
The direction of wind, currents and waves probably have more to do with your speed, as will ballast or the condition of your boat. Any of these could make the port tack faster for you. Owners of furling sails sometimes report seeing a difference on one side.
So your "dominant" side may have little to do with it, but there is one way to find out.
Put 2 marks perpendicular to the wind, along a constant depth and have your left-handed crew time your speed runs.
When that's done, let them sail the course several times and compare notes.
Maybe you can settle this - and find out if both of us should be doing more "left-handed" curls. :wink:
PostPosted: Wed May 01, 2013 7:02 am
I'm not so sure about this dominant side theory.
I'd check the setup of the hulls, if they are still parallel. Check the pylons for movement. Check the rudders for proper alignment. Chek to see if the rig is setup the same port and starboard.
As you become a better sailor, steering should be more by feel than anything else. You will know when you are in the groove by how the helm feels. That leaves your sight for sail trim and conditions.
Chris
'88 H18SE Arís
PostPosted: Wed May 01, 2013 7:55 am
But don't you think it is possible your feel is better one way or the other?
PostPosted: Wed May 01, 2013 11:42 am
I'm not too sure I get the gist of this subject. Unless there is a problem with the boat, or the skipper is very one side dominate, any difference should be minor. And if there is a difference, what does it matter, you still have to make both port and starboard tacks. :roll:
PostPosted: Wed May 01, 2013 5:50 pm
+1 Ron. I posted this same question on catsailor several years ago with similar responses.
Did you check this? Have you measured that? one hull weighs more than the other...to ad nauseum.
The vast majority still believes if your boat's not fast there's something wrong with everything but the tiller nut.
I can get my head "out of the boat" easier on port tack. This has been true with the dozens of cats I've owned. Much like golf (putting specifically) I think having your dominant eye trailing (if you will) helps you see the line better. [I'm right-handed]
1984 H16 "Mister Rogers"
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
PostPosted: Fri May 03, 2013 6:06 am
I must admit in the past I have wondered the same thing... I used to feel faster on one tack. I thought maybe it was the boat somehow, perhaps a shroud just a little longer on one side etc... However these days I don't notice any more and I never made changes to the boat. Boats still the same, so maybe it is nut on the end of the tiller and over time I adjusted and became more ambidextrous? :lol:
2011 H16... Have a Hobie Day!
1983 H14 Turbo...
PostPosted: Fri May 03, 2013 4:19 pm
There you have it Ron. You are not nuts.
Or if you are, you're in good company.
