It is currently Wed Jun 24, 2026 5:49 am
PostPosted: Thu Apr 24, 2014 2:32 pm
Talking H16
Thought about buying some 5/8 tube online and making my own with hardware I have around, but even here,
http://www.carbonfibertubeshop.com/small%20tubing.html (Would need one SM6230F $39.75 and one SM6260F $69.50... Plus a couple sleeves at 10 bucks a pop)
It seems the cost of buying the tube, a bit of epoxy, ect is closing in fast on just buying a carbon tiller extension which is ready to go...
Although I am considering building one out of some Hockey sticks.. :)
Building one allows me to more easily have parts ready to fix it if I break it (which I probably will) but with the cost seemingly to close in pretty quick on a 98" Harken "battlestick"... I am thinking about the value of time.. Which commercially available sticks are the "best"? Or any thoughts from ya'll on what you have like and what you have not. I am mainly looking for light weight (tacking maneuvers) and as stiff as possible to give me all the feel I can have on the tiller.
www.thehobiewayoflife.com
PostPosted: Thu Apr 24, 2014 6:08 pm
A 98" Ronstan battlestick is $150
PostPosted: Thu Apr 24, 2014 7:54 pm
Buy 3 of the 60" tubes, cut one in half, then glue the short pieces to the long pieces with the sleeves.
Then you have two tillers.
PostPosted: Fri Apr 25, 2014 6:41 am
That is the answer!!!!! The ONLY way to go.
Remember there is a very good chance that you will break one in a breeze if you get a little outta control.
But no one here does that!! :roll: :roll: :roll: :roll: :roll: :roll:
PostPosted: Fri Apr 25, 2014 8:14 am
I have a kevlar stick that came with my boat. It's pretty ugly because it hasn't been painted but very light and strong.
Zach
PostPosted: Sun Apr 27, 2014 10:00 pm
Pretty much the answer I expected...
This look like the right stuff?
http://www.rockwestcomposites.com/products/45553
Should be able to build them for just under 100 a pop using hardware from old fiberglass sticks..
Do I want 5/8 OD or ID?
(So now I'll just need to tape the extra one under the tiller crossbar for quick change outs WHEN I break em... :lol: )
