It is currently Mon Aug 10, 2026 9:28 pm
 Post subject: Sail bag or Sail tube?
PostPosted: Thu Sep 11, 2014 2:34 pm
Looking for advice about the pros/cons of a sail bag versus a sail tube.
I picked up a Wave this spring, got homemade trailer that I modified/widened to hold the Wave and we've had a great summer. I plan to eventually upgrade to a 16 or similar in a few years as my kids grow.
Which is better a bag or tube for the sail(s)?
Thanks - Brian
PostPosted: Thu Sep 11, 2014 2:45 pm
Neither is better. You should always put the sails into their bag and then put them into the tube (or box, or your car).
PostPosted: Fri Sep 12, 2014 6:05 am
both see my post on sail bags
PostPosted: Fri Sep 12, 2014 10:42 am
Thanks for the advice. I got a tube today and will look into making a sail bag.
PostPosted: Mon Sep 15, 2014 5:37 pm
Do you just roll them up wet and stuff them into the bag? Seems like it would mildew pretty bad. I guess when you get home you have to roll them out in your yard to air them out and let them dry.
PostPosted: Mon Sep 15, 2014 6:25 pm
Sails should be dry before you roll them up.
Best way is to leave them up for a bit after you're done sailing. Although there have been times (raining) when I've had to roll them wet. Then I unroll them in the (finished) basement to let them dry for a day or two.
PostPosted: Tue Sep 16, 2014 4:56 am
If your in salt water, you may want to rinse them and hang them to dry as often as possible as well. I hang mine via bungees off my car door opener rails. Makes for a handy way to spray them down too because my contractor was smart enough to recommend drain holes in the garage when I built.
I'm not sure how much effect salt has on modern sail material and the threading but it tends to eat through everything around here. I rinse mine after every sail pretty religiously but I could be paranoid.
