It is currently Sun Jun 21, 2026 3:23 pm
 Post subject: where to put a knife
PostPosted: Thu Oct 30, 2014 12:27 pm
hi,
i have a hobie sidezip/stolquist wedge pfd, my new knife recently came in (http://ceramicknife.org/product/eod-knife/) I got the nylon sheath to. is the pocket the best place to put it, or can i be sewed on to the strap?
thanks angelo
http://youtube.com/optikid16030
1983 Hobie 16 Cat fever #55697
2008 Laser Radial/4.7 #190471
S.S.S.
S.Y.S.P
 Post subject: Re: where to put a knife
PostPosted: Mon Nov 03, 2014 7:48 am
Call me paranoid I don't trust most sheath knives if they are friction fit only,to stay in place if the sheath is sewn to the PFD, strap, etc. Some will obviously be more foolproof than others and yours may be fine. I just don't want a sharp knife flailing around at the end of a lanyard, should it get knocked loose. Therefore , my vote for a sheath knife is in the pocket (assuming you can retrieve it one handed.)
I've been sea kayaking since before sprayskirts slipped off so easily as they do now so I always carried a knife I could grab and open easily with one hand only. My current one is a folding Spyderco that is designed to be flipped open with a a thumb flick. It has a very tight clip that secures to my PFD and I have a lanyard attached as well. The bulk of the long lanyard sits out of the way in the pocket it clips to. Although it's never come loose, it will at least be closed if it does.
PostPosted: Mon Nov 03, 2014 8:28 am
Same here I don't trust sheath knifes as much as I like foldable knifes that I keep in each pfd (would hate to get cut accidentally). We are scuba divers and I don't mind sheathed knives attached to my my leg, arm, or BC (would love to have the ceramic knife you show for diving but not so much for an emergency sailing knife (just my opinion of course). My foldable stainless knife I fill with Vaseline then fold, and wipe all the Vaseline off the outside then throw in my pfd pocket (helps prevent corrosion). I've been cut before so I'm kind of paranoid about loose knifes.
Hope this helps
Bob
PostPosted: Tue Nov 04, 2014 11:26 am
http://ceramicknife.org/product/nylon-s ... eod-knife/
I wouldn't trust just the friction fit ether. I have it in the pocket of my lifejacket now, but it almost doesn't fit. If this knife works good then I'm going to get the more expencive one that folds
S.S.S.
S.Y.S.P
PostPosted: Sat Nov 29, 2014 8:05 am
I like the Myerchin lite knife crew, smaller one, with locking marlin spike.
I find that is useful when rudder kicks up but cam does not. fits in pocket
of pfd
PostPosted: Thu Dec 04, 2014 8:50 pm
Best knife I've ever owned.
http://www.benchmade.com/products/3300
PostPosted: Sat Dec 06, 2014 9:47 am
always carry a telo ss marine knife. i keep it around my neck when rigging and tied to the life jacket when sailing. This has worked for me over the years
Former hobie admiral gary
PostPosted: Sat Dec 06, 2014 12:39 pm
I use a multitool like this
The pliers help to do-undo shackles.
H17
