It is currently Thu Aug 13, 2026 7:52 am
PostPosted: Mon Jul 20, 2015 7:16 am
I new to sailing and recently "inherited" a Hobie Cat during the purchase of an estate property. The Hobie has been out in the elements for at least 8 years and needs some work to get it on the water again. I'm having trouble identifying the model Hobie... I believe it is a Hobie Cat 16, but don't know how to make 100% confirmation before I start buying parts. The Serial # near the rear rudder is CCML9992M80B. Can someone tell me is this indeed a Hobie Cat 16 or some other model? Thanks!!
PostPosted: Mon Jul 20, 2015 12:47 pm
Hi there!
Based on the serial number, the boat was built in 1980, but I don't believe you can tell the model from that number. Fortunately, it's pretty easy to tell the difference visually. First of all, Hobie only had 3 models of cats in 1980:
Hobie 14:
14' 3" Length over all
No trapeze wires by default, but could be added on
"banana shaped," asymmetrical hulls (V shaped bottom)
trampoline raised up on 4 pylons
No forward (jib) sail by default, but could be added on
Fixed mast (doesn't rotate), no diamond wires or spreaders
Mainsail will likely have a number 14 in a circle near the "flying H" (Hobie symbol) at the top
Hobie 16:
16' 7" Length over all
trapeze wires are default
Jib traveler cars on forward crossbar
Mainsail will likely have a number 16 in a circle near the "flying H" (Hobie symbol) at the top
Hobie 18:
18' length over all
symmetrical hulls (U shaped bottoms)
crossbars bolt directly to hulls, trampoline flush with hull
Hulls have "daggerboards" that slide down through the hulls through a slot in the hull
Hulls have deck ports just aft of the forward crossbar
Rotating mast with diamond wires and spreaders
roller furling jib that overlaps the mainsail/mast - jib blocks along inside edge of hulls/alongside trampoline
"loose footed" mainsail doesn't slide into a boom track
Mainsail will likely have a number 18 in a circle near the "flying H" (Hobie symbol) at the top
One piece of advice, before you get too far into fixing up the boat: check for soft spots. Given that the boat was left in the elements, it's possible that it wasn't well cared for and could have developed them over time. Press down hard on the decks and sides of the hulls. If there's minimal deflection, they're good. If there's significant deflection, or you hear a crunching or cracking, the boat has a soft spot. If there are only a few, they're easily fixed. If it's most of the deck/side, the boat is beyond saving. Check the length of the decks and sides. They're most common on the decks just forward or aft of the crossbars, where the crew frequently step or sit.
Hopefully the hulls are still in good shape and you can get it back out on the water again! Hobie cats are just about the most fun you can have on the water!
Post back with any further questions! :)
Mike
'78 H18 (unnamed) sail #14921
'08 H16 sail #114312
'97 H21SC sail #238
PostPosted: Mon Jul 20, 2015 4:14 pm
Probably is. Post a couple Picts.
The Wind Is Your Friend...
PostPosted: Wed Jul 22, 2015 1:04 pm
Mike,
Thank you very much for all the detail! Based on the 16'7" length I'm now sure it's a 16. Thinking it may have been "customized" in the past though since the mast does rotate. All the logos are gone from the mast so I'm not seeing the 'H' or the '16', but all the other details are spot on. I'll examine the hulls well b4 I start spending any money in it.
Thanks again,
Bruce
PostPosted: Thu Jul 23, 2015 1:48 pm
Mike,
As far as I know, all beach cat masts, rotate.
Not sure about AC72's though....
2015 H16, with spin,
PostPosted: Fri Jul 24, 2015 6:58 am
John Lunn wrote:
Mike,
Apologies, my mistake. I'm not quite as familiar with the H16 as the H18, but I had thought that the non-captive mast base and mast rotator were features exclusive to the 18, so I figured the smaller cats did not have mast rotation. Thanks for the correction! :)
Mike
'97 H21SC sail #238
