It is currently Sat Aug 01, 2026 2:52 pm
PostPosted: Tue May 10, 2016 11:46 pm
Is it possible to find a replacement zipper, just the piece you move, for my 30 yr old sail? Or what other options do I have? Can it be used without being zipped? Loose luffed.
PostPosted: Wed May 11, 2016 6:29 am
The best bet on an old sail is to get your local dealer to sew on a new zipper. I got Rooke Sails here in Memphis to replace my jib zipper and it's bigger ( teeth ) and stronger than the original. It costs around $150 but well worth it.
Tim Grover
Memphis, TN fleet 134
Hobie 20! G-Cat5.0 and 2 Hobie 14's
Photobucket now wants $100 to post pics on forums......... pass.
PostPosted: Sat May 14, 2016 12:10 pm
Beacon Fabrics has what you need. You want the 186" zipper and UV thread. Costs around $25. I had a seamstress sew mine on.
http://www.beaconfabric.com/vindex.html?cat160.htm
PostPosted: Mon May 16, 2016 12:35 am
Yep I got mine from the link above. It was actually about 2" shorter than my original but not a big deal. I've been hand sewing it back on myself since my sewing machine hates doing a zig zag stitch on thick stuff
PostPosted: Mon May 16, 2016 9:01 am
I would not suggest sailing it like this. The luff needs to be zipped.
PostPosted: Fri May 27, 2016 6:48 pm
It might work to replace just the zipper slide, I have not done it on a hobie jib but have done it on quite a few other plastic zippers. Its easy to do just have to unsew or take the little zipper stops of the end of the zipper to get the new slider on then sew it back up or put new little crimps on it. The hard part might be finding the right size slider. Campmore used to sell a zipper repaire kit. might look there to see what they have and also see if they have any directions for doing the repair.
