It is currently Sat Aug 01, 2026 8:51 pm
 Post subject: Serial# search
PostPosted: Tue Mar 20, 2007 1:42 pm
I just bought an old H16 in Southern California and I need to register it at the DMV, but the Serial numbers got covered by a new coat of paint.
I need the serial# to make out the DMV forms.
Is there a way I can get a serial# related back to a sail number, which I do have....hoping its the original sails.
Alternatively, is there some solvent that I can use to disolve the paint and expose the covered serial#. I imagine its some kind of epoxy paint that was used by the looks of it.
Help! Suggestions???
Ray
 Post subject: Serial numbers
PostPosted: Tue Mar 20, 2007 3:57 pm
There is no direct correlation between sails and hull serial numbers. Not even something you can determine the year of a hull by. They are not matched up by the factory in any way. We used to (when I worked for a dealer) completely mix and match sails and hulls. Sometimes keeping sails or hulls for years before matching them up for a sale.
Maybe sand paper? Till you get to the original surface? Then the paint would make the serial number engraving stand out (assuming contrasting colors of course).
PostPosted: Tue Mar 20, 2007 5:12 pm
You could try making a rubbing. Since the serial number is engraved,
it could work.
To make a rubbing put a piece of paper over the area and rub it with
a hard crayon (paper removed) or the side of a pencil lead.
Do this BEFORE sanding!
 Post subject: Helpfull suggestions
PostPosted: Wed Mar 21, 2007 2:52 pm
Unfortunately the cover paint White, matches the original white hull....maybe slightly off, so sanding will be a last resort.
I'll try a rubbing but visually the surface looks smooth so I'm not very optimistic.
Were all the serial numbers free hand Electric Pencil Etched?
Ray
 Post subject: Yes
PostPosted: Wed Mar 21, 2007 4:08 pm
Yes, since 1973.
http://www.hobiecat.com/support/warrant ... erial.html
