It is currently Sat Aug 01, 2026 6:40 pm
 Post subject: Too Much Heat Gun!
PostPosted: Fri May 25, 2007 6:38 pm
So I'm working on my "new" '92 H14 Turbo, with rock solid hulls, removing the racing stripes (which were a little crackled along the edges) -- like I don't have enough to do -- in preparation for a thorough cleaning & wax job. I'm using a heat gun and "GOOF-OFF" which are working fine, if slower than I'd like. Then, I get distracted admiring the shine on a part of the hull I already waxed, while pointing the heat gun at the stripes, and I hold it there too long. When I look down, the area of the hull that was getting hot (just below the forward pylon) is forming a raised welt about the size of my palm!
:shock: I let it cool, and it sank back down, and now is slightly indented, and it gives a little if I push hard on it. I can hear the faintest creak when I do this. :cry: Did I delaminate this area? Is this going to get worse and come back to haunt me? I could just kick myself!
PostPosted: Sat May 26, 2007 7:26 am
Beer will do that. Sounds like you melted the foam under the glass.
PostPosted: Sat May 26, 2007 9:13 am
Just leave it alone. If it's where the hull stripes are, then it's not in a real high stress area.
Pushing on it will just make it worse.
