It is currently Fri Aug 21, 2026 1:31 am
PostPosted: Mon Jun 20, 2022 8:45 am
As a pretty experienced Hobie sailor, I almost always tack.
Is there a definitive guide as to when to tack vs jib.
How often do you jib?
PostPosted: Mon Jun 20, 2022 11:01 am
I (almost) always jibe going downwind
Unless it's blowing so hard to do so would be dangerous
1984 H16 "Mister Rogers"
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
PostPosted: Mon Jun 20, 2022 1:35 pm
Jibe or Gybe...
A jibe (US) or gybe (Britain) is a sailing maneuver whereby a sailing vessel reaching downwind turns its stern through the wind, which then exerts its force from the opposite side of the vessel.
Tacking is for when you are moving upwind. Jibing is for anything from a beam reach to DDW (Direct down Wind) and is the most fun!
PostPosted: Tue Jul 05, 2022 9:29 am
Gybing can seem very violent. Rigging in good condition can handle it tho. I usually will sheet things in real snug in preparation. bring the traveler in also. Perform the gybe then let evthing loose. Hobies are dogs dead downwind, so unless necessary, you shouldn't be at this point of sail anyways. ( with a spin, ok)
PostPosted: Tue Jul 05, 2022 5:01 pm
It might seem counter-intuitive, but the faster you’re going when you initiate the gybe, the less violent it will be. This is because the apparent wind direction will be farther forward, effectively reducing the true wind speed. Get going on a broad reach as fast as you can and preferrably surfing down a piece of chop or swell. Then make a decisive turn downwind. I personally wouldn’t tighten and center the mainsheet because that is going to make the boat less inclined to turn downwind and could cause a capsize if you start to round up unexpectedly. I would recommend physically grabbing the mainsheet stack and throwing it over to the new side when the boat reaches dead downwind. Don’t wait for the wind to flip the main over to the new side as that would be very violent and could hurt someone.
PostPosted: Fri Jul 22, 2022 7:32 pm
Recreational sailing, it doesn’t matter to me. Gybing is easier for me if inexperienced crew is aboard in mild winds. High winds require crew who know how to backwind the jib.
PostPosted: Mon Jul 25, 2022 8:14 am
Does not have to be violent. Start bearing away... Sheet for a reach... turn facing aft as you start steering through the jibe. Grab the mainsheet in a bundle up at / near the boom block. Pull down and as you pass DDW... ease it back up and then out through the jibe to the other side. Sheet and travel out again. I never just let it swing wildly and crash to the other side.
PostPosted: Mon Aug 01, 2022 9:55 am
If you are playing in the surf, or surfing downwind you gybe.
If your are in big wind with rough seas on a 14 you might not be able to tack, so you gybe even though you are trying to get upwind. I saw guys doing that in some races in the 70's.
PostPosted: Wed Aug 31, 2022 4:40 pm
Solo in heavy air it's way easier for me to gybe than to tack.
'00 H16 #104691
Old Holsclaw trailer
My Hobie 16 pages
