It is currently Sat Aug 01, 2026 7:58 pm
PostPosted: Thu Nov 08, 2007 11:26 am
I found the following when searching the internet for a simple review of the Hobie 16 to be posted on an informational web site.
Interesting what people can come up with when left to their own devices.
Enjoy :shock:
I’m on my 3rd Hobie 16 and have made a few modifications to avoid having the thing fall apart on me sailing it balls-to-the-walls.
Both hulls developed cracks inside and just forward of the forward tramp support post(s) when cranking down the mainsheet sailing tight to windward. My fix for this was a section of galvanized fence piping and 2 bolt hole caps bolted across the front of the bows in the same holes used by the 2 forestays. This keeps the bows at the same width and works as hand holds when pulling the boat around on the beach.
I also added a second sidestay to each side and tension each pair share the load equally.
On the 2nd Hobie I had a welder weld a second stainless dolphin striker support and then added a second dolphin striker in tandem with the existing one. My first Hobie fell apart when the striker parted.
These 3 mods beef the boat up a bit. I have sailed my boat hard for a number of years and it has held up well, but I worry about the single striker - if it fails and the load on the main isn't eased ASAP, the tramp supports will break.
HCANA Class Member
PostPosted: Thu Nov 08, 2007 11:27 am
Yikes!
PostPosted: Thu Nov 08, 2007 1:28 pm
I would think that boat would be awesome in a demolition derby.
PostPosted: Thu Nov 08, 2007 1:38 pm
Dang! Thanks for posting that!
I see all sorts of crazy mods to Hobies. My rule here at the shop is that if I see one ferrous-metal bolt, washer, rivet or anything I simply won't work on it. I don't need the headache.
The H16 is a well engineered boat. How many of them are still sailing from the 70's... a ton... that's 30 years!! Like anything, they just need to be taken care of.
I see repairs that people do that cost more than just getting the correct part. A guy came in the other day with an 18 and he, "couldn't get the shrouds tight". I went out to take a look, and he had a 7X19 X 1/8" home built (nicopressed) forestay that was 6" too long. I asked him why he didn't just buy the right part and he said they cost too much. Well, they're around $60...$40 less than he spent for a part that was the wrong wire, the wrong length, the wrong swages, using a non calibrated tool.
Not only was this more pricey, it was dangerous. With boats, the addage ," it pays to do it right the first time" is amplified.
Sail Revolution
Join us on our new FB Page!
