It is currently Sat Aug 01, 2026 7:58 pm
 Post subject: 16 jib repair
PostPosted: Thu Dec 20, 2007 11:19 am
[img]IMG]http://i264.photobucket.com/albums/ii186/abbman/jibsail002.jpg[/img][/img]
[img][img]http://i264.photobucket.com/albums/ii186/abbman/jibsail003.jpg[/img][/img]
James
86' Redline Hobie 16
Sail # 76909
PostPosted: Thu Dec 20, 2007 11:22 am
How can I go about fixing this?? The top of the jib was ripped out after a de-masting. Is this something I can personally fix?? Or does it have to be sent off somewhere?
If I can fix it what will I need and what will I need to do?
Thanks.
I've been having to borrow jibs and would really like to get this fixed so I'm no longer dependant on others for their jibs, not that they haven't been very helpful.
James
Sail # 76909
PostPosted: Thu Dec 20, 2007 1:14 pm
It looks to me like you'll need to do some reinforcing of the head prior to pounding in a new, slightly larger grommet.
Alternatively, you could cut the head down a bit, then use nylon strap to attach a small SS ring.
Either way, you probably want to have a loft do it. They'll have the tools for pounding in the grommet, the right sized grommet and the machines strong enough to sew it. Hand sewing anything more than a couple of layers of dacron gets to be tedious.
Brian C
p.s. There's an Ullman loft in Oriental
PostPosted: Thu Dec 20, 2007 1:35 pm
Thanks Brian, I look into the loft.
James
Sail # 76909
PostPosted: Thu Dec 20, 2007 2:04 pm
I had Chip at whirlwind sails fix my similar break and he did an awesome job.
PostPosted: Wed Dec 26, 2007 7:46 am
Abbman,
I have been successful at using tent shops for that type of repair. They have the proper sewing machines and grommets. You may need to supply some sailcloth for reinforcement, they will not have cloth
 Post subject: email
PostPosted: Thu Dec 27, 2007 8:11 pm
Check your email.
Trey Brown
www.velocitysailing.com
2006 N20 1017
1998 H16 102698
www.sunjammers.com ftw!
