It is currently Sat Aug 01, 2026 9:11 pm
PostPosted: Thu Apr 24, 2008 9:23 am
I've done a search on this, and couldn't find what I need to know. I have a'93 H14T and plan on storing it on its trailer, mast-up this summer. It has white hulls, and a faded black mesh tramp. The trailer is galvanized. Last summer it sat in the garage, and under a tarp behind the garage over the winter.
Here's the question: Is it really important to cover it up in the boatyard this summer? How damaging is the sun? Rain? I'm in Michigan. I'm inclined to modify my winter tarp to use this summer, but am I being too protective?
PostPosted: Thu Apr 24, 2008 11:54 am
Sun and air pollution are bad for boats.
Keep it under cover.
PostPosted: Thu Apr 24, 2008 11:59 am
Thanks, Matt.
 Post subject: cover that thang!
PostPosted: Mon May 05, 2008 1:43 pm
Yes, sun bad, acid rain bad, sun bad!
I would invest in a cheap tarp to cover it. I have found a couple cheap tarp bungies and a few quick clips make it very easy to quickly install and or remove my tarp. You may have to get cleaver to work around the mast.
I also clean my boat off and use 303 protestant to seal the fiberglass. Helps keep crud off and protects from UV damage
PostPosted: Tue May 06, 2008 4:38 am
Andrew,
I've never heard of "303 protestant". What's that? What brand name is it sold under? Thanks.
Mark Van Doren
H14T Fantasia #47787
San Juan 28
PostPosted: Tue May 06, 2008 5:14 am
Google is your friend.
PostPosted: Tue May 06, 2008 8:07 am
Thanks Mat. Had I Googled 303 "Protestant" I might have wound up in church. :lol:
Mark Van Doren
San Juan 28
 Post subject: 303
PostPosted: Tue May 06, 2008 8:12 am
Use caution when applying anywhere you need traction.... i STRONGLY suggest you dont do it on the tramp, top of hulls and anywhere you would need to stand durring righting.
I have used it on my hulls, blocks, even my snuf bag. I am thinking about doing it on my mylar sails... THe car is next
I would do a search at CatSailor.com's forums and read all about it. Thats where i learned about it....
