It is currently Fri Jun 05, 2026 5:35 pm
PostPosted: Sun Jun 20, 2010 6:25 pm
Today I was out when I heard a poping sound and noticed the mast was leanning back after a close inspection inside the hatch I found a broken screw that hold the V- frame , and the V-frame has now a 1/2 inch space between the hull and the mast receiver. If I look down into the mast cup it's leaning toward the back. My question is how many screw are holding the mast receiver from the botom of the hull I see there is two plastic caps if I am looking underneath the hull from the outside. I might be able to reuse this screw as it snapped near the top of the nut. How do I fix this should I loosen the V-Frame turn buckle.
PostPosted: Mon Jun 21, 2010 1:56 am
That sounds scary! I'd be having my dealer have a look.
Don't think it's a very common problem.
PostPosted: Mon Jun 21, 2010 2:26 am
Certainly I'd be seeing my dealer.
It might not be broken. The bolt is actually a stud I think.
Check out this post and Philip1el's reply. The pics give you an idea of how the mast tube is attached.
viewtopic.php?f=75&t=14472&p=87023&hilit=+brace#p87023
PostPosted: Mon Jun 21, 2010 10:45 am
Maybe the nut backed off?
PostPosted: Mon Jun 21, 2010 5:54 pm
Thanks guys I took it apart and found that the screw was broken at two places. I put a new one in.
