It is currently Fri Aug 07, 2026 11:38 am
PostPosted: Tue Sep 14, 2010 5:14 pm
Last time I was out the handle was hardly turning the rudder, so I need help on how to tigthen the line it's the left line that is loose .
1) Do I tight it by loossening the bolt on the rudder
or
2) is it done from the inside through the rear hatch wich seem to be realy hard to reach.
(excuse my english)
Dan
PostPosted: Wed Sep 15, 2010 4:38 am
Dan,
When I adjusted mine I did it at the screw on the rudder. You might want to give a Hobie dealer a call before you mess with it though.
Jerry D.
St. Johns, Florida
2010 TI
2008 AI
PostPosted: Wed Sep 15, 2010 9:35 am
All line tension is handled at the rudder.
We have instructions here: http://www.hobiecat.com/support/articles/archive/?src=http://2010.archive.hobiecat.com/support/tech/Twist-n-Stow_Repair_Manual.html
PostPosted: Wed Sep 15, 2010 4:18 pm
Thanks guys for your help I have fix the problem.
I guess this is something I will have to put on my check list to make sure I have the right tension on the line.
Dan
