It is currently Fri Aug 28, 2026 3:28 am
 Post subject: H21SE Tramp Track
PostPosted: Tue May 02, 2006 4:30 am
I have a H21SE and am having a problem with the tramp track. This is probably not a unique 21 problem. The track has rotated upward and caused the inboard edge of the rivet heads to bend upward. This in turn has caused the track to be loose. I looked through the inspection port and can make out the bottom of the rivets. Any suggestions on how best to affect a repair of this problem? I'd rather not go nuts with a drill until I'm sure the procedure is correct. Thanks for any ideas!!
