It is currently Sun Aug 16, 2026 10:40 am
What Compound to Use For Soft Spot Repair?
Git-Rot 100%  100%  [ 3 ]
Other Generic Epoxy 0%  0%  [ 0 ]
Urethane (Gorilla Glue, etc.) 0%  0%  [ 0 ]
Silicone 0%  0%  [ 0 ]
Poly-sulfide sealant 0%  0%  [ 0 ]
Asphalt 0%  0%  [ 0 ]
Chia Seed and Green Tea 0%  0%  [ 0 ]
Sponge Bob Barnacle Glue 0%  0%  [ 0 ]
Aussie Didgeridoo Juice- Now With Koala! 0%  0%  [ 0 ]
Hobie Brand Crack Filler with that California $urfer Extra$ 0%  0%  [ 0 ]
Total votes : 3
PostPosted: Sun Jul 17, 2011 9:52 am
Location: Latrobe, PA, USA *** Show YOUR Location - Edit Profile ! ***
I have a soft spot to fix and I certainly appreciate all the info here about what to do and how but... I'm wondering about Git-Rot brand versus other epoxy mixes.
I can certainly do better from a price point on a thin 2-part epoxy with 30+ minute working time- so, is there anything really superior about Git-Rot (brand)?
Also, and related, is there a general way to calculate based on the area of the soft spot on top of the hull how much epoxy I need- since it has a finite shelf life?
I imagine it would be related to the density of holes drilled into the top hull layer- 1 hole/sq.in., per 4 sq.in, etc. and what drilling pattern is adequate for an acceptable repair?
Thanks for your input!
Raise your sail one foot, and you get ten feet of wind.
起你的一只帆,和你10英尺的。 -- Chinese Proverb
William D. Latinette @ Latrobe, PA, USA w. H14 Turbo X 2... [email protected]
PostPosted: Sun Jul 17, 2011 10:07 am
Penetration, viscosity, hardness when cured (not too hard), bonding strength, easy application... All good with Git-Rot
PostPosted: Mon Jul 18, 2011 7:18 pm
nothing magic about git-rot...it just works
buy a kit of it and your use questions are answered in the instructions
Sheet In...Max Out
www.fleet297.org
