It is currently Wed Aug 12, 2026 10:07 am
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Aug 09, 2011 6:11 am
Was wondering if any has installed a side/down imaging transducer on the angler pro would appreciate any feed back on this matter
PostPosted: Tue Aug 09, 2011 1:13 pm
i believe the humminbird HD DI works good as a shoot-through, but the SI transducer needs an unoibstructed image so it must be in the water...you are talking about the humminbird right?
USCG Licensed Master 100GT Near Coastal
2011 Hobie Pro Angler
PostPosted: Tue Aug 09, 2011 2:04 pm
I have a Humminbird 798si (side imaging) fish finder installed on my PA using Madfrog's sideboards and transducer deployment arm. When I launch I snap my mirage drive in then swing the TDA over the side near and off I go. The only issue I have had is forgetting to pull of the arm when I head towards the beach. Its very resilient but you don't want to ground it on a concrete boat ramp with the arm down.
http://www.madfroggear.com/specialtyboa ... oards.html
It doesn't show the deployment arm on the site but the side boards are pre-drilled for the the arm and I really like the extra mounting space I get with the new side boards.
RedWolf3773
Rigged for War!
PostPosted: Tue Aug 09, 2011 2:27 pm
Could this transducer be mounted threw scupper holes
PostPosted: Tue Aug 09, 2011 2:31 pm
Yes it is a hummingbird my last kayak ocean trident the transducer was mounted threw the scupper would the view still be obstructed for the down/side scan
PostPosted: Sat Dec 10, 2011 11:13 am
What did you figure out on this? I have the 598ci HD DI Combo. I was thinking of hanging my ducer off the back. I am going to take a thin piece of aluminum and install it under the stern rail and bolt the ducer to it. My friend has a similar setup on his Ride 135 and has no issues.
https://picasaweb.google.com/1034393126 ... 0564926594
PostPosted: Sat Dec 10, 2011 11:15 am
I think the DI has to be in the water based on my calls to Humminbird.
Have you tried this? I have it through hull on my Tarpon right not and it isn't working that good.
PostPosted: Sat Dec 10, 2011 11:57 am
Salt warrior when you have a finished project would it be possible for you to Post a photo this forum thank you ✌
PostPosted: Tue Dec 13, 2011 11:52 am
Sure, I am going to the the Ram/Hobie Anal Probe so that I do not have to drill anything. If that does not work, I am going to install a 4in Gear Trac on the Stren Rail and try that.
I am trying not to drill anything because I am hoping Humminbird will come out with a scupper mount transducer for DI like the Lowrance.
PostPosted: Tue Dec 13, 2011 12:27 pm
I did a through hull mount (temporary) on my pro angler last weekend. Hooked up a 597hd di combo and got very good imaging. I am going to side mount this weekend and see if there is any measurable difference.
PostPosted: Tue Dec 13, 2011 3:44 pm
Salt warrior I seen the YouTube video on the anal probe where would you get a hold of that to purchase it
PostPosted: Tue Dec 13, 2011 4:01 pm
I am about to order...
The guy who came up with the Ram/Hobie Bung Anal Probe is
Kevin (Kevlar) Winchester
Kevin Winchester < [email protected]>
0412 464 832
This is the guy in the video...
Scott Lovig < [email protected]>
12 C Satu Way
MORNINGTON 3931
03 5975 6399
0418 566 626
Scott writes:
We are the global centre for Ram/Hobie bung anal probes but are sold out of the original batch. I also had a batch made in black nylon which are neater but don’t grip as tightly with the ram clamping arm. It’s no problem, just rough the ball up a little if you want a tighter grip. They are $25.00 and postage is $8.00 standard mail.
www.slhobie.com.au
PostPosted: Fri Dec 23, 2011 12:46 am
0412 464 832
12 C Satu Way
MORNINGTON 3931
03 5975 6399
0418 566 626
Scott writes:
http://www.slhobie.com.au
It says there is a slot cut in the side of the probe for the transducer wire to fit thru. It looks like a nice way to route the wire but wouldn't that allow water to enter the kayak?
http://www.kayakbassfishing.com Pro Staff
http://www.yakattack.us Pro Staff
http://www.mariner-sails.com
http://www.TFOrods.com
PostPosted: Fri Dec 23, 2011 8:15 am
These guys say that it will not leak. The said put some silicon on it and that it actually rides higher out of the water than you would think. I have one headed my way. I will post a full review when I get it all hooked up after the holidays.
PostPosted: Fri Dec 23, 2011 11:04 am
Cool thanks. Now if I was reading right they aren't aluminum like the first ones were? They mentioned something like them being nylon?
