It is currently Mon Jun 22, 2026 12:54 am
PostPosted: Wed Apr 11, 2012 10:17 am
I bought an '85 H18 last summer. The mast has a flotation "pad" that is screwed to the mast on the upper portion of the mast. Can I just remove it and plug the screw holes? It seems really bulky and I don't use it (much).
Anyone have any experience with this device?
Jim
H16 20645 Blue Streak
H18 930 Blue Streak
H18 3385 Carumba
H18 ???? Blue Hawaii
H18 12497 Blue Hawaii
PostPosted: Wed Apr 11, 2012 6:16 pm
Yes you can remove it no problem. You are correct in thinking that you have to plug the holes. Make sure you seal them holes good, and then its a good time to seal the rest of the mast.
You said you don't use it often, nobody uses it often, well I know a couple people who use it more than normal. But its that once in a while when you capsize when you really wish you had it.
Sail # 10505 or 277
Image Image
PostPosted: Tue Apr 17, 2012 10:33 am
Thanks for the feedack. I'll be removing it later this spring. If anyone wants it, let me know and I'll package it up to send when I do.
Thanks sincerely,
Jim
H18 930 Blue Streak
H18 3385 Carumba
PostPosted: Tue Apr 17, 2012 11:50 am
I've sealed my entire mast rivets and all 'cept the area behind the sail track where the comptip joins with the stick. I'm considering popping out the track and sealing this area and was wondering if you guys did the same? I hate the thought of one potential leak in that critical mast/comp tip joint (although the yellow foam is supposedly seated in pretty far).
My mast seems to be pretty watertight. At least I think so - I've had the boat on her side for upwards of 15-minutes without turtling and there doesn't seem to be any water sloshing around inside the mast.
PostPosted: Tue Apr 17, 2012 11:55 am
Don't have a comptip so I don't worry about that. #$%! I just found a crack under my mast base.
Sail # 10505 or 277
Image Image
PostPosted: Tue Apr 17, 2012 12:13 pm
On the front crossbar?
PostPosted: Tue Apr 17, 2012 12:49 pm
No the mast base on the rear crossbar.
Just kidding.
viewtopic.php?f=13&t=42206
Sail # 10505 or 277
Image Image
