It is currently Tue Jun 16, 2026 6:40 pm
PostPosted: Tue Jul 16, 2013 6:35 am
So I picked up a used H18 furler off the Forum, and bought the kit from a Dealer....
borrowed some snap-ring pliers, watched Jeremy/Surf City's video, and set to work.
Usual snags.... wife does not like me working on the dining room table, then she helped me
with the removal of the larger snap ring.
From what I can see, this furler must have been salt water sailed, there is some corrosion,
and there are no bearings!
How do I loosen the s/steel screw that locks the drum onto the centre metal part?
WD-40? Heat? Do I destroy the drum, and then vice-grip the head of the screw so I can extract it?
Sometimes, the simplest things in the world don't turn out the way you expect.....
Anything else I should watch out for?
2015 H16, with spin,
PostPosted: Tue Jul 16, 2013 6:44 am
I would soak in WD-40, liquid wrench, or PB Blaster and then remove the screw.
Inspect the yoke carefully....viewtopic.php?f=13&t=45180
PostPosted: Tue Jul 16, 2013 6:51 am
Thanks for the quick response....
I'll definitely not do the soaking in the dining room....
Yes, I checked out all the welds and joins veeeery carefully, I remember the problem you posted.
cheers !
PostPosted: Tue Jul 16, 2013 7:09 am
John - I just did mine last week. Had the same issue: tried soaking in WD-40 overnight - to no avail. Ended up cutting away the plastic drum with a hacksaw until only the screw was left. Still wouldnt budge. Then I managed to get the head of the screw into a vice and rotate the furler. That did the trick. Sure to use grease when re-installing; good for lube, and holds the bearings in place while you put it back together.
Jim
