It is currently Sat Jun 13, 2026 8:30 pm
PostPosted: Sun Sep 08, 2013 5:26 am
I blew out the locking holes in the drum and need to replace it (81173001)
from normal use after 1 yr it actually blew thru to the next hole so that there is a slot instead of holes.
My question is what other parts will I need to acquire besides a new drum?
Will the drum shaft fit snuggly after swapping etc?
PostPosted: Sun Sep 08, 2013 3:39 pm
The newest drums for V2 drives have a medal plate molded in so it shouldn't happen again to you.
PostPosted: Sun Sep 08, 2013 8:11 pm
Awesome to hear! I will make sure my replacements are of the newest!
PostPosted: Mon Sep 09, 2013 4:29 pm
Same thing happen to one of my drum. The part I picked up at my local Hobie Dealer looks like the old style drum. If your drums are worn, they swing left right, then replace as a pair...
Paul
DogsLife
2011 Adventure Island
PostPosted: Sat Sep 14, 2013 10:58 am
I have not been able to find a supplier that knows about the metal plate... any chance you know the part #?
PostPosted: Sat Sep 14, 2013 11:18 am
Hobie mostly uses the same part number on upgraded parts. Should be #81173001 same as the old V2 drums, so not much help.
PostPosted: Mon Sep 16, 2013 12:06 pm
You can see the plate by looking into the adjustment holes.
This has been in production for quite awhile now, so any stock is likely the newer version.
