It is currently Sat Apr 11, 2026 12:56 pm
 Post subject: Haka seat
PostPosted: Sat Sep 28, 2013 11:47 am
I read the the 57 pages and looked at all the cool modifications to create a haka seat on both the TI and the AI. I have a TI and would like to run a full length haka seat so I can hike out a little from the rear seat where I like to steer. I was thinking of installing an Xbar assembly behind the rear seat and running a piece do tubing through it to support the rear of the haka seat. Any thoughts on my idea or has someone already completed the project and give me some advice on how to support the rear of the haka.
Thanks for the help and these great forums
Sent from my iPad using Tapatalk HD
 Post subject: Re: Haka seat
PostPosted: Sat Sep 28, 2013 12:20 pm
viewtopic.php?f=69&t=38827
PostPosted: Sat Sep 28, 2013 3:13 pm
Thanks Chrisj - I thought some would have already build something similar to what I'm thinking except the tramps don't work for me, 6'4" 230lbs the snaps broke the first time I sat on my tramps and I would like a higher seat to sit up a little.
PostPosted: Sat Sep 28, 2013 5:52 pm
This would be the way to do it.
We use Hakas on the rear position exclusively now.
Read on. Right on,...
PostPosted: Mon Sep 30, 2013 2:37 am
Cantelever Hakas as always an option for hiking out from the rear algough you cant get back as far as you can do with the Ti3
Cc
PostPosted: Mon Sep 30, 2013 2:58 pm
230LB is a lot of weight. Even for the TI3 design.
Most of the hull/Ama floatation is concentrated in the front/center of the boat, so hanging a big slab of meat off the rear does tend to sink that area and creates drag, along with rudder stress.
Still, a third rail seems like the best option, unless Jholt wants to fly from the front position.
Lemme know offline if you need advice on this.
PostPosted: Mon Sep 30, 2013 7:09 pm
Thanks Nohuhu I would like a little help on this, I plan to pilot a little forward of the existing rear seat, across from the drive to trim the boat out a little. The plan is to order a Xbar, left and right AKA, 2 brace assemblies and a couple of brace posts. Mount the new Xbar behind the rear seat, cut of the two AKA arms to an undetermined length and build a 4 board haka bench and bungee it to the AKA's. I'm sure. There is a lot more to it than that but won't know the pit falls until I run across them, you could be a big help in that for sure. I have been reading the haka bench seat topic and not seeing the rear aka except for one photo, but have not finished the topic yet, it is really long but quite fun read, I'm surprised Hobie hasn't provided the option yet, it would make the sailing a lot more fun and a flatter ride. I sail off west Maui just south of Napili so 15 to 20 knot breeze almost every day and withstand tramp deployed you have to reef a lot or your going over, hiking out would be a huge advantage. Sorry for not going offline but don't know how to do that.
Thanks for your help
John
PostPosted: Mon Sep 30, 2013 7:16 pm
I'm doing the same mod. I've got all the parts, just haven't put the time aside to install it. You are welcome to come down and check out what I've got. All based on the great TI3 I got to ride on by NOHUHU and Batman. Batman actually made me a great set of plates to reinforce the inside of the hull for the 3rd aka x-bar. I feel a little guilty I haven't done it yet.
PostPosted: Mon Sep 30, 2013 7:35 pm
Thanks Bob, I would appreciate taking a look at your handy work what your schedule looking like
Mahalo
John
PostPosted: Mon Sep 30, 2013 7:44 pm
Great. If you need help, just pick up the Batphone.
PostPosted: Mon Sep 30, 2013 9:41 pm
Available most of the time, PM or email.
PostPosted: Tue Oct 01, 2013 9:45 am
Aloha Bob - How about I come by around 11:00 this morning, does that work for you
thanks again for your kindness
john
