It is currently Wed Jun 10, 2026 3:25 am
 Post subject: Sail control line mods.
PostPosted: Mon Nov 25, 2013 1:53 am
After using my new AI 2 or 3 times I got very annoyed with the control lines getting tangled up with my feet and the mirage drive. After reading about other solutions to this problem, I decided to do something about it. Here is my version of 'Spooks' mod. So much better now, no more tangles and much easier to control.
2021 Dune Hobie Lynx
PostPosted: Mon Nov 25, 2013 2:15 am
I've been looking at doing something similar for the furling line only.
Unfortunately I can't relocate the cleats to that position, as I have Scotty flush-mounts in that spot.
How did you go about attaching the harken carbo block to the crossbar - did it fit trhe exisiting screw-holes?
Cheers,
Mike.
PostPosted: Mon Nov 25, 2013 2:33 am
You could try this way http://modernkayakfishing.com/articles/ ... g-line-mod
Sent from my A500 using Tapatalk
PostPosted: Mon Nov 25, 2013 3:01 am
Cheers,
Mike.
Had to make slight adjustments to the harken to fit the existing holes.
PostPosted: Sat Mar 01, 2014 12:24 am
Hey Hogman, Nice work by the way.
I have been looking at doing a similar mod to better position the furling line in the back seat of my TI.
I already have the Yakattack track mounts in that position. What fitting did you use in the track mount to be able to flush mount the plate for the Harken cleats. I assume that you made the plate for the cleats out of alloy plate.
I see Josh has also used a similar mount on the main sail rope but again, I can't see what fitting to use in the track. All the fittings I have for Yakattack track have a bolt sticking up but not a plate to screw a bolt into and end up with a flush bolt head.
Cheers
Geordie
Geordie
West Ausie
