It is currently Tue Jun 16, 2026 3:19 am
PostPosted: Tue Jan 07, 2014 7:13 pm
looking for a source for the 2 stern drain plugs. thanks
PostPosted: Wed Jan 08, 2014 11:55 am
The drain plugs for the hull are same as H20 - and still available from any dealer - not sure about the cockpit drains - those are showing discontinued so you might need to make one:
http://static.hobiecat.com/digital_assets/holder-12-parts-guide.pdf
Jacques Bernier
http://www.hobie.com/
PostPosted: Thu Jan 09, 2014 5:27 pm
great. thank you very much.
PostPosted: Fri Jan 10, 2014 12:30 pm
The hull plug thread is also what is used on our small kayak drain plugs.
79050211 DRAIN PLUG - 3/8" W O-RING&KEEPER
Cockpit plugs were basically a rubber cork. You can drill a hole through them to run a keeper line though.
