It is currently Thu Aug 27, 2026 11:38 am
 Post subject: Paint the frame black?
PostPosted: Tue Oct 10, 2006 6:19 am
Just wondering if anyone thinks it would be possible to paint the frame or mast of an old H 14 black to make it look a bit newer/better?
Phil
Hobie 14 Turbo
Victoria, Australia
 Post subject: Paint
PostPosted: Tue Oct 10, 2006 8:30 am
Paint on aluminum would look really nice... till you start using it. It chips off too easily.
PostPosted: Wed Oct 11, 2006 5:42 pm
Matt is right. You may want to try "Krylon" name brand primer. Through trial and many errors, I've found that it works the best of everything I've tried. Goes on easy, smooth finish and reasonably durable. (after all, it is paint) If you try to paint over it, you'll ruin it. It looks very good just by itself. Know that I've only tried it on the mast and boom. I can't vouch for the frame.
Happy Sailing,
PostPosted: Wed Oct 11, 2006 7:05 pm
Before paint I would consider powder coating the front and rear cross bars. Sides have the carpet so no need.
Or for a more forgiving finish and cheaper I would go with a do it yourself truck bed liner product such as "herculean"...sold at auto zone...it comes in quarts and will remain flexible meaning it wont peel like paint by the constant expanding and contracting of the alum with temperature...thats why paint doenst stick very well to it.
Truck bed linner stuff will take the banging of the boom and other stuff without any marks + it will be satin just like the original black anodized alum...
It will also seal the alum completely encapsulating like rubber from salt water.
Thats what ill do in a couple of weeks if no other idea crosses my mind!
"Black spray on or roll on bed liner"
And its not a thick as u imagine...it can be quite thin a coat depending on how u apply
Any other ideas???
PostPosted: Wed Oct 11, 2006 10:37 pm
Sorry its not "herculean" but Herculiner:
http://www.herculiner.com/stores.html
Check out marine applications:
http://www.herculiner.com/other_uses.html
There is also a similar product called "Ultra Tuff Coating" that I saw and read about a year ago on the boston whaler forum...
here it is:
http://www.ultratuff.net/utmindex.htm
PostPosted: Wed Oct 11, 2006 10:41 pm
I wonder if I can get something like that in Australia? I'll have to have a look around. Thanks for all the advice!
Phil
Hobie 14 Turbo
Victoria, Australia
PostPosted: Sun Oct 29, 2006 11:04 am
Hello:
Have a look at this post:
http://www.hobiecat.com/community/viewtopic.php?t=3774
Personally I painted my clear mast the "cheap way" described in that post and as Matt says where there´s friction paint chips off, but I think it still looks better than before, if you say that you want to do the job on an old boat maybe "cheap way" is a good option.
1983 HC16
PostPosted: Sun Oct 29, 2006 7:35 pm
Try some stuff called Penetrol first. About $19 a can. I have heard it works Great. I am going to try it on my 17.
Doug
PostPosted: Mon Oct 30, 2006 3:03 pm
I have used flat black Krylon and Rustoleum on my aluminum extrusions over the years. for about $5 you can get a new look each year. Yes, the paint does chip off in high wear spots, but you can easily repaint and get that new look in a matter of one evening... if it is that important to you. I would rub down the area you want to paint with acetone. This will help it adhere better.
I would avoid powder coating as it can be expensive since you have to find someone with an oven large enough to handle the long parts. Also, this will chip and will be harder to repair.
If you go with Herculiner or somthing similar, be careful on surface that mate to castings, blocks, trackt, etc. The material is thick and will interfere with mating surfaces.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Thu Nov 16, 2006 9:02 am
I would not paint the mast with the truck bedliner stuff. I don't think you would want that much weight aloft. Being in the car business I know that doing a full size pick up truck with the Rino Liner adds about 475 lbs to the truck. You would not think it weighs that much but it does. The Autozone stuff may be thinner and wiegh less but I don't know.
PostPosted: Thu Nov 16, 2006 10:20 am
Sorry If u guys understood me wrong...I woudnt do the mast with any liner material...like Jack said...it will add to much weight. I have decided not to coat the crossmembers either as they are still in good shape..anodized black with some scratches.
The only spar Ill recoat will be the boom with powdercoat after I weld the not in use rivet holes. Of course it all depends on how expensive it would be...I have to find out this next week. If it turns out to be a hastle Ill just use sailing gear stickers over the smoothed out welds, Harken,RWO,etc.
This weekend Ill be recoating the hulls with gelcoat/duratec...Ive been repairing gudgeon plates, loose pylon and scratches for over a month now and finaly have it ready to spray.
After that it will be to re-rivet the mast step and drill for 5/8" pylon bolts.
And the list goes on....
PostPosted: Thu Nov 16, 2006 10:38 am
My kid take the Krylon flat black and does a light spray on this mast when we get it out for spring. Makes it look like new, take 5 minutes, last all year and cost $4.
 Post subject: Thought on powder coat
PostPosted: Thu Nov 16, 2006 3:52 pm
Powder coating the mast is an option but I don't think you can powder coat non metalic objects, like the comptip.
PostPosted: Thu Nov 16, 2006 5:14 pm
I dont think so either as the whole idea behind powdercoating is the electric charge that is run thru the metal that attracts the opposite charged powder to stick before baking
The comp tip I did with epoxy primer and automovite urethane jet black paint...came out sweet,, That was about two months ago ,,,sitting in the sun every day...no bubbles or blemishes...I know it will hold up well when in use.
 Post subject: Flex
PostPosted: Thu Nov 16, 2006 5:58 pm
Do you think when the comptip flexes that the paint might crack?
